Marc Posted October 11, 2007 Posted October 11, 2007 i have yokohama s306 14" tyres. There isn't a pressure reading on it to tell me what it should be at.Anyone Know how many PSI front and back? Quote
Guest Enzo Posted October 11, 2007 Posted October 11, 2007 i usualy set mine pretty hight usualy 34-40 psi but in the book they are usualy around 30-32psi Quote
Marc Posted October 11, 2007 Author Posted October 11, 2007 i usualy set mine pretty hight usualy 34-40 psi but in the book they are usualy around 30-32psiThat 40 at the front and 34 at the back or opposite? Quote
Rich Posted October 12, 2007 Posted October 12, 2007 usually more at th front as you need to compensate for engine weight. Quote
riko666 Posted October 12, 2007 Posted October 12, 2007 if you look in your glovebox, or Car Manual, it'll tell you, 36-32 front to rear if I recall correctly Quote
StarletRick Posted October 12, 2007 Posted October 12, 2007 go and drive the car pretty hard for about 10 mins. and then take the pressure. you want to try and get it so that when hot all tyres are about 32 psi. they will differ from front and rear. Quote
lobotomy Posted October 12, 2007 Posted October 12, 2007 It also depends what type of driving you do, mostly motorway driving means a slightly higher tyre pressure. Quote
