mattglanza79 Posted August 30, 2013 Posted August 30, 2013 Guys.Car has started jolting when on boost. Idles fine and can rev right up with no misfire.Not sure if its missing or a feeling fault. Drives fine off boost. Doesn't jolt all the time either. Nearly diednon me a min a go. And no ecu light and boost down so want be cut Quote
akyakapotter Posted August 30, 2013 Posted August 30, 2013 Sounds like fuel cut do a diagnostics test bud Quote
TurboTobz Posted August 30, 2013 Posted August 30, 2013 Check ignition parts, first check dizzy and rotor Quote
mattglanza79 Posted August 30, 2013 Author Posted August 30, 2013 Defo aint fuel cut. Boost is no where near high enuff Quote
mattglanza79 Posted August 30, 2013 Author Posted August 30, 2013 Its the plugs. Proper knackered. Sharp enuff to pose as a needle. No do I fit ngk irridium 6 or 7 or any other plug like bosch etc Quote
mattglanza79 Posted August 30, 2013 Author Posted August 30, 2013 Just looked online there meant to be like that. Had to clean theking lead coil contact so see if that's done it Quote
mattglanza79 Posted August 30, 2013 Author Posted August 30, 2013 Was my king lead. Thanks peeps Quote
