19ryan91 Posted August 31, 2013 Posted August 31, 2013 hi guys bare with me new to this well I have just bought a little white glanza v its standard at the moment but looking to get it a little faster my mate just sold me a td 04 hybrid turbo weper manifold decat pipe walbro 255 fuel pump & a front mount intercooler will I need bigger injectors & a better ecu ? Quote
DevonGT Posted August 31, 2013 Posted August 31, 2013 Yes, if you want to run a decent amount of boost. But on a standard engine you won't be able to run that turbo at it's full potential. Quote
russ78 Posted August 31, 2013 Posted August 31, 2013 theres still gains to be had at stock boost with that setup mate , but as above if you want to raise boost to lets say 1Bar its recommended to run better management emanage Blue at the very least Quote
drew 007 Posted August 31, 2013 Posted August 31, 2013 Do things properly do things once!! Best of luck with the ep91 mate. Quote
ste91 Posted August 31, 2013 Posted August 31, 2013 With what you've got there, plus a 2.5 inch exhaust system and something like GReddy E-Manage you could make an easy 200bhp, you might need injectors too but I'm sure someone else will verify that. Clutch will probably be on it's limits too, standard internals will be fine. However if you wanted to use that turbo to it's full potential then you should consider forged internals, clutch, etc... Quote
yaristurbo Posted August 31, 2013 Posted August 31, 2013 i ran standard injectors at 1.3 sotck 4e 255 walbro Quote
