Hoping to buy drew's unit however it is for an ep82 ..what will I need to change to get it to work with my ep91? Specifics - or is it not possible.
Hoping someone knows to stop me pestering Mike at td on Monday.
James
Wrong thread - could a mod move into relevant mapping section?
JamesWrong thread - could a mod move into relevant mapping section?
You would have to get hold of a ep91 ecu connector, and use it to rewire the harness that came with the power fc. Ive actually done this myself, and it works perfectly.
Pretty much. You will need get some heatshrink tubing aswell, the kind thats lined with glue. So you can cover up the solder joints. Also its a good idea after you have finished the loom to fill all the backside of the connecter where your solder connections are with hot melt glue. This is mainly for added support and to stop any straining of the solder connections.
Take note! You'll need get both the pinout diagrams for ep82 and ep91, compare the two and take it from there. Dont worry about the extra 16 or so pins on the glanza connector, there only used on the automatic. Also there is are 2 'sensor earth' pins on the ep82 ecu, and only 1 on the glanza, all you need to do is solder the 2 together on the one pin on the glanza side of the loom.
Also u can buy the connector from RS-components
http://uk.rs-online.com/web/p/pcb-connector-housings/7201005/?searchTerm=Hybrid+connector+54&relevancy-data=636F3D3226696E3D4931384E44656661756C74266C753D656E266D6D3D6D61746368616C6C7061727469616C26706D3D5E5B5C772D5C2E2F252C5C735D2B2426706F3D3926736E3D592673743D4B4559574F52445F4D554C54495F414C5048415F4E554D45524943267573743D48796272696420636F6E6E6563746F722035342673633D592677633D4E4F4E4526
