Banbury Glanza Posted September 1, 2013 Posted September 1, 2013 Hi guys atm I'm running a TD04 on a fully forged engine with all supporting mods, I've been offered a vf30 in nearly new condition and just wanted to know what people's views were on the VF30. Is it worth doing it as I will need a re-map as soon as it's on. And what sort of power gains would I see ?? I'm running 260 bhp atm but would like to see 300 bhp if possible. Thanks Todd Quote
mikey4410 Posted September 1, 2013 Posted September 1, 2013 I would also like to know the difference between the two Quote
AdamB Posted September 1, 2013 Posted September 1, 2013 (edited) They offer a little later spool up as a VF24, but a little less top end power than the VF22 which I believe is the biggest in the range upto 400bhp I think it is.The VF24 is the most comparible with the td04. What power gains you will see depends on what boost you decide to run it at. Edited September 1, 2013 by AdamB Quote
Banbury Glanza Posted September 1, 2013 Author Posted September 1, 2013 I'm not sure what it would be run at obv want it running safely Quote
Phil Posted September 1, 2013 Posted September 1, 2013 Currently what's your limiting factor?If you get the vf turbo on there, what would hold you back?Injectors big enough to flow 300hp region?Ignition alright plugs tight enough for the boost?Clutch setup game for a power hike?Compression sensible enough so as to not make the tuners job impossible on big boost?Phil Quote
Banbury Glanza Posted September 1, 2013 Author Posted September 1, 2013 Yea injectors are 440 maybe bigger not sureIgnition all good mateClutch is a 6puk paddle Compression should be all good Quote
Phil Posted September 1, 2013 Posted September 1, 2013 (edited) Alright sounds like you'll only be dealing with normal issues like the odd broken gearbag lolGet it on there and mapped, the extra lag will be the only downside Phil Edited September 1, 2013 by Philm Quote
