Ollieh17 Posted September 1, 2013 Posted September 1, 2013 (edited) Just taken everything apart to find i have a hole actuator and a pin turbo!!anything i can do, nut and bolt maybe? Need a quick fix Edited September 17, 2013 by Ollieh17 Quote
Ollieh17 Posted September 1, 2013 Author Posted September 1, 2013 I meant to say the new actuator is hole and the old one was pin Quote
1990timeismoney Posted September 1, 2013 Posted September 1, 2013 U can buy pins that fit on ebay or just nut and bolt make sure nut and bolt not to big because it mite not clear part of turbo I had the same problem Quote
1990timeismoney Posted September 1, 2013 Posted September 1, 2013 300955377643Not the same one but is the same if u ask for diametre it should be ok Quote
Ollieh17 Posted September 1, 2013 Author Posted September 1, 2013 Don't suppose you know what diameter is needed? Put everything back together now... Round two another day Quote
1990timeismoney Posted September 1, 2013 Posted September 1, 2013 It should be ok with the bolt I dont have a actuator im sure someone will be able to tell you Quote
Ollieh17 Posted September 8, 2013 Author Posted September 8, 2013 Ive managed to get a nut throught the hole but the bolt keeps popping out the wastegate.. Just use a ciriclip on this?? Or can i put a nut behind the bolt. Dors the actuator pin have to pivot in the wastegate hole Quote
Ollieh17 Posted September 8, 2013 Author Posted September 8, 2013 Can you acty bolt the nut up? Does it not need to pivot within the wastegate? Quote
Ollieh17 Posted September 17, 2013 Author Posted September 17, 2013 Ive fitted the actuator and have fiddled around. But however short i make the actuator boost seems to go no higher than 0.6bar..it also seems to have more lag than it did before. On the standard actuator the boost was also at 0.6bar and i believe stock high boost is 0.8bar. I have the high boost/low boost removed. Any ideas? Quote
Mel85 Posted September 17, 2013 Posted September 17, 2013 doesnt shortening the pin keep the wastegate open? hence the lag? sounds like you're hinging the wastegate open Quote
Ollieh17 Posted September 17, 2013 Author Posted September 17, 2013 (edited) Shortening the pin keeps the wastegate shut i always thought? Edited September 17, 2013 by Ollieh17 Quote
Mel85 Posted September 17, 2013 Posted September 17, 2013 my bad! should have engaged my brain for this one.. shortening keeps the wastegate closed tighter/pre loads the actuator. Quote
Mel85 Posted September 17, 2013 Posted September 17, 2013 yea my bad! shortening the actuator pin tightens/pre loads the wastegate, so in theory should run slightly higher boost before opening. a mate of mine fitted a small camera under his bonnet when he was having actuator trouble and showed it wasnt closing/opening... might be worth doing the same Quote
Ollieh17 Posted September 17, 2013 Author Posted September 17, 2013 Just fitted a new exhaust and its less laggy...still not at full boost till 5krpm Quote
Ollieh17 Posted October 2, 2013 Author Posted October 2, 2013 Still pretty sure, even with the actuator even shorter that im only seeing 0.5bar boost. When it goes up to 0.7bar im pretty sure this is just creep as it only does it in 4th and 5th and alot more often now its cooler. Now have removed and completely blocked off the BOV which i thought would solve the issue. Quote
