FrancyGlanza Posted September 5, 2013 Posted September 5, 2013 Currently running as 1.4 athena m/s headgasket on standard engine with 150psi across all cylinders What would compression be with TRD 0.6 Gasket Quote
PaulStarletSR Posted September 5, 2013 Posted September 5, 2013 would be higher, i know that much! Quote
FrancyGlanza Posted September 5, 2013 Author Posted September 5, 2013 yeah i know it would be higher but by how much ? What compression would iii be at ? Any one able to work out it ? Would be running a fensport hybrid at a bar Quote
AdamB Posted September 5, 2013 Posted September 5, 2013 (edited) Its hard to say without taking measurements of the piston volume and the combustion chamber volume as it depends if the head/blocks been skimmed before. But you'll be fine! Much better to have higher CR anyway. You don't really need to be worrying about CR's on that kinda setup Edited September 5, 2013 by AdamB Quote
FrancyGlanza Posted September 6, 2013 Author Posted September 6, 2013 Yeah head was skimmed beforenot to bad soanyone else any experince with them or any other input Quote
rmsnoel Posted September 6, 2013 Posted September 6, 2013 A google search will bring up a few online calculators and old threads with the figures you need. Quote
AdamB Posted September 6, 2013 Posted September 6, 2013 Phil managed 260bhp with a 0.6mm gasket at 1 bar on a td04. They work well Quote
