steviet Posted October 16, 2007 Posted October 16, 2007 What is the going rate for a respray? been quoted £1000 or there bouts for respray in same colour. Quote
RobSR Posted October 17, 2007 Posted October 17, 2007 thats not bad, you could get one cheaper, and you could get one more expensive, thats about in the middle i would say..... but if you do go for a cheaper one they will most probably not take out the glass, and it will then start to peel.Have a look at these two companies - GVN Coachworks - not cheap but one of the best - Knight Racer - will have contacts to a good spray shop.Hope this helps mate!Rob Quote
Nanglebadger Posted October 17, 2007 Posted October 17, 2007 i assume thats simply the outside stevie man?? i'd say thats maybe about right, u might get it slightly cheaper dependin where u go i guess but as i have found with paintin the last thing u want is a bad job done! if u know your payin alot of money but gettin a damn good job then i'd be happy!Phil. Quote
paul w Posted October 17, 2007 Posted October 17, 2007 I would think that'll be a reasonable for that price. A decent one will be around £1500 that'll include under bonnet and door shuts etc,but as it's the same colour those areas probably wont need doing.Make sure you get to see previous work done by them and if possible speak to the owners of the cars done.Also make sure you shop around Quote
steviet Posted October 17, 2007 Author Posted October 17, 2007 Thanks very much for the advice lads,gonna shop around and see what there works like.The quote i did get was from a friend to,ill have to wait and see Quote
shelly_star Posted October 17, 2007 Posted October 17, 2007 Hmmm or maybe ask someone that is from Ireland seeing that the ones here will be useless to you Quote
