Catalogue Thred | Dyno Graphs
this post is strictly for dyno graphs and specs to go with them,
hopefully this will build into a thred full of dyno graphs so get posting :)
The graphs:
And the spec:
Engine/Turbo:
Autofixed FMIC
Apexi Filter (Mounted behind the grill)
Road Runner Manifold
Blitz Decat
Custom straight through ss cat back exhaust
HKS Actuator
NGK Iridium Spark Plugs
NGK Blue Leads
Walbro Fuel Pump
SARD RRFPR
SARD R2D2
Carbing Cooling Panel
TRD Reservoir Covers
GReddy Emanage Blue
Greddy Profec E-01 @ 15psi
  • 1 month later...
My Blitz K24 Setup at 1.1 Bar.
Spec List:
Performance Parts:
3G Big Brake Kit (285mm)
Braided Lines
Apexi Power FC
Apexi AVC-R
Apexi Air Filter relocated to front bumper
Blitz K24 Turbo
Blitz External Wastegate
Blitz Downpipe
Cusco Oil Catch Can
Full 2.50 Custom Exhaust system
Denso Uprated Fuel pump
Evo FMIC with custom pipework
HKS SSQ BOV
Magnecor HT Leads
NGK Irradium Plugs
ORC309 Clutch & Lightened Flywheel
RR Mild Steel Manifold (Braced)
RX7 460cc Injectors
SARD Sports Radiator
SARD RRFPR Package
SARD Racing thermostat
SARD 1.3 Bar Radiator Cap.
Section Engine Damper Kit
TRD Engine Mounts
Wilwood Calipers
Air Con removed
Handling:
Cusco Lower Arm Bar
D2 Full Coilover Set
Greddy Rear Strut Brace
Greddy Front Strut Brace
Whiteline Panhard Rod
Interior:
Dual pillar pod
Greddy Electronic Water Temp Gauge
AEM Wideband
Exterior:
Zep Racing Fenders
ROTA JSPL 16in Alloys
TOYO Proxies T1-R's all round
Quad Light Conversion
  • 5 months later...
Guest Enzo
Ricks TC Glanza
Engine
5E Decked Block
5E Balanced Crank
4E Ported & Mirror Polished Head
Clevite77 uprated Bearings
Pauter Forged Rods
Ross Forged Pistons
Ross Racing Rings
Cruise Power Headgasket
Cruise Power Valve Springs
JAM Racing Cams
JAM Racing Underbucket Shim Kit
SARD 550cc Injectors
Ported & Polished 5E-FHE ACIS Dual Runner Intake Manifold
4A-GE Ported Throttle body
SARD Fuel Regulator
SARD MAG+ Sump Plug
SARD MAG+ Oil Filter
Greddy TD-06 Turbo
Cruise Power Manifold
Cruise Power Downpipe
Cruise Power Screamer Pipe
Fujitsubo Power Getter Exhaust
HKS S/S Racing External Wastegate
Custom FMIC
Cruise Power FMIC Hard Piping
Walbro 255lph Fuel Pump
Clevite 77 Uprated Oil Pump
Greddy Airinx Filter
ULTRA 7mm Plug Leads
Silk Road Engine Torque Damper
Custom Polyurethane Engine Mounts
SARD Oil Catch Tank
Venhill Braided Throttle Cable
Aeroquip -AN Fittings and Braided Lines
NGK Iridium IX Grade 8 Plugs
Royal Purple 10w30
All Hotpipes Thermal Wrapped
All IC pipes Reflective Wrapped
Spec
CT9 @ 1bar
TRUST GReddy Type-R Racing Blow Off Valve
GReddy Profec B Spec II Boost Controller
A`PEXi Power Intake Universal 70mm
FMIC Core 530x235x65mm
WEPR FMIC Piping kit with hoses and clamps
OEM Clutch Kit
SARD Fuel Pressure kit
Cusco Oil Catch Can Kit
Toy Tuning CT9 Mild Steel Manifold Kit
Blitz Decat Pipe
2" 1/4" bore straight Exhaust system
GReddy E-manage Blue
Magnecor 8.5mm Spark Plug Leads
NGK Iridium heat range 7 Spark plugs
*Sorry about the poor quality pics; don't have a scanner at my uni house! :D
Graph:
My two runs:
Performance parts:
At the time of the run:
CT9A
HKS Actuator @ 11psi
WEPR FMIC
Unkown backbox on standard exhaust system with middle silencer removed.
Japspeed De-Cat
Air filter
Current spec today:
Autobahn Mani
Front exit exhaust with Tanabe backbox
CAP Clutch (old one slipped a bit)
K&N Filter located on end of EFI pipe (EFI Pipe heat lagged)
HKS Actuator @ 10psi (turned it down, lovely creep :( )
Possible plans for this summer:
RRFPR & JAM FCC or JAM ECU (if I can save enough/find one!)
Re-located filter to behind bumper
And setup to run 1Bar
Aim: Near 150~ish HP atw if thats at all possible; I'd be chuffed.
Also note; at that RR day every person lost near on 40hp transmission loss. I refuse to believe that to be accurate; its a tiny FWD tranny not a massive 4WD system, so 40hp loss seems rediculous to me. Don't know what was going on. I will get it RR'ed again when setting the car up, see how much that makes!
  • 2 weeks later...
Guest Enzo
Michaels Tong turbo G spec hybrid at 1 bar
unichip fitted and mapped by Paul Hills @ Engine Advantages in Witham.
Car produced just under 214BHP @ the flywheel and 196lb/ft torque running 1BAR
dyno run
spec Small breather Filter
Magnecor Leads
Irridium plugs
Garrett/CT9 Hybrid
Dastek Unichip
WEPR FMIC
WEPR Full system
Walbro Fuel pump
S/S Manifold
HKS actuator
Blitz dual solenoid boost controller
Air con removed
Filter off turbo
TRD quickshift
Exeedy uprated clutch
SARD RRFPR
Autometer boost/oil pressure gauge
EBC brake pads
HKS SSQV
HKS FCD
Thermotec heatwrap
Samco hoses
ENGINE
4E-FTE
wossner forged pistons
wossner forged rods
Fully balance bottom end
Gas flowed and polished head
Ported and polished inlet manifold
2mm head gasket
Light weight Crank pully
Custom manifold (heat wrapped)
Custon pipework
Custom front mount intercooler
Custom oil cooler
Custom oil catch tank
Custom braided oil and clutch lines
Custom turbo water lines
Custom Front exit exhaust (heat wrapped)
HKS GT25/30 roller bearing turbo
HKS air filter
HKS ssqv blow off valve
HKS actuator
Greddy emanage ultimate management
Greddy Profec B boost controller
Sard 550cc injectors
Sard Fuel Pressure Regulator
Walbro Uprated Fuel Pump
Magnecor 8.5mm leads
NGK Iridium plugs
TRD engine mounts
Blue hoses
Drivetrain
Standard Gearbox
Exedy Organic Clutch
TRD Quickshift
Chassis/Suspension
KYB shocks
Eibach springs
Front and rear strut braces
Cusco lower arm bar
Whiteline Adjustable Panhard Rod
Whiteline Anti-lift/Castor Kit
BRAKES, WHEELS
EBC brake discs with EBC green stuff pads
MR2 15" wheels powder coated mat black
Goodyear eagle F1's tyres
INTERIOR
A pillar pod for gauges
Defi Link Boost gauge
Defi Link Oil Pressure Gauge
Defi Link EGT gauge
Defi Link controller
3 point harnesses
Alpine head unit
  • 5 months later...
bit more up to date
ENGINE
4E-FTE
wossner forged rods
2mm head gasket
Custom tubeular manifold
Custon hard intercooler pipework
Custom oil cooler and braided lines
Custom braided clutch line
Custom braided turbo oil line
Custom braided turbo water lines
Custom braided FPR lines
HKS air filter
HKS actuator
Magnecor 8.8mm leads
NGK Iridium plugs
Blue hoses
Carbon cooling panel
Electronics
Greddy emanage ultimate with main, injector and ignition harnesses
Greddy emanage 3bar pressure sensor
Greddy knock sensor adaptor
Greddy Profec B Spec 2 boost controller
Greddy Turbo timer
Defi Link EGT gauge
Drivetrain
Standard Gearbox
TRD Quickshift
Chassis/Suspension
TRD engine mounts
Tein Type Flex Coilovers
Cusco lower arm bar
BRAKES, WHEELS
Wilwood 4 pot calipers
3G 285mm discs
Braided lines
spec:
WEPR Manifold
TD04 Turbo
Tial external wastegate
WEPR front mount intercooler
Screamer pipe
Blitz Supersound BOV
HKS exhaust system
7mm Ultra leads
Wiseco 74.5 forged pistons
Scat forged conrods
Full engine rebuild
NGK Iridium heat 8 spark plugs
Walbro fuel pump
550cc Sard injectors
Zep racing 1.2mm headgasket
Greddy profec E-01
Apexi air filter relocated
Greddy Emanage blue ECU
CAP 4 paddle clutch
WEPR De-cat
Oil catch tank
Subaru WRX 2006 seats
Oil pressure/Water temp/Boost gauges
Team dynamic 16" motorsport white alloys
EBC brake discs
EBC Green stuff pads
Full TRD Suspension
Standard toyota front strut brace
standard toyota rear strut brace
  • 2 months later...
Full spec is below:
Performance Parts:
Wiseco Racing Low Compression 75mm Pistons
Wiseco Racing Piston Rings/Pins
Scat Forged Conrods
Zep 2mm Headgasket
Power Enterprise Cambelt/Tensioner/Idler Kit
New OEM Toyota Head Bolts
New OEM Toyota Complete Engine Gasket Set
New OEM Toyota Oil Seals
New OEM Toyota Water Pump
New OEM Toyota Oil Pump
New OEM Toyota Valve Stem Seals
Crank Bearings replaced
New Mainend Bearings/Shells
Full Bottom End Rebuild
Port & Polished Stage 2
Block Professionally Rebored/Honed
Head Stripped/Cleaned/Re-Shimmed
Block painted (Blue)
Braided Lines
Apexi Power FC
Gizzmo Electronic Boost controller
High Flow Filter
SPS - Custom Turbo
SPS â?? Custom Made Downpipe
SPS - Custom made top mount manifold
Tial 38mm External wastegate with screamer pipe
Manifold Thermal Ceramic Coated (Race Coated)
Intercooler pipework fully thermal reflective coated
Custom breather system on rocker cover venting to atmosphere
Blitz Nur Spec Exhaust System
Walbro Uprated Fuel pump
HDI Front Mount Intercooler
HKS SSQ BOV
Magnecor HT Leads
NGK Irradium Plugs
Exedy Ceramettalic Clutch
Cusco 4.1kg Lightened Flywheel
HKS Fuel Rail with braided hoses
SARD RRFPR Package
CX Racing Dual Core radiator
TRD Engine Mounts
Wilwood Calipers
Air Con removed
Handling:
Cusco Lower Arm Bar
Whiteline rear ARB
Whiteline front ARB
Interior:
Dual pillar pod
AEM Wideband
Apexi Power FC Commander
Exterior:
Carbon Fibre Bonnet
Zep Racing Fenders
Yokohama A539 on rear + TOYO Proxies on front
Quad Light Conversion (Coming soon)
  • 1 month later...
  • 7 months later...
Speedvision Hybrid Turbo
HKS actuator @.95bar
Autobahn88 FMIC
Apexi Power Intake Induction Kit relocated to front bumper
5Zigen Decat pipe
HKS Super SQV Blowoff valve
Japspeed manifold
Blitz Nur-spec exhaust
A'pexi AVC-R boostcontroller
A'pexi AFC NEO
HKS FCD
A'pexi turbotimer
TRD Leads
Iridium Sparkplugs.
