Hunty Posted September 19, 2013 Posted September 19, 2013 (edited) On the way home tonight the car starting holding back. Every time I got to about 0.7/0.8 bar of boost it really held back and started popping almost felt like I was anchoring on the brakes. Anybody have an idea on what this might be? Currently running a tongs hybrid set to 1.0 bar emanage blue etcThanksBrad Edited September 19, 2013 by Hunty Quote
The Toffinator Posted September 19, 2013 Posted September 19, 2013 Have you checked the Ignition system? Plugs leads dizzy etc? First port of call Quote
Sefton-EP91 Posted September 19, 2013 Posted September 19, 2013 Have you checked the Ignition system? Plugs leads dizzy etc? First port of callThis mate ^^^ Check ignition components for general wear and tear, leads, plugs, cap and arm etc. Quote
Mikeyallgood85 Posted September 19, 2013 Posted September 19, 2013 Don't rule out a boost leak! Quote
Chris Green Posted September 19, 2013 Posted September 19, 2013 Fueling? Have you got a wideband? Quote
Hunty Posted September 25, 2013 Author Posted September 25, 2013 Thanks for the response guys have been poking round the engine bay and found a hole in the back of a intercooler pipe it was rubbing against the gearbox going to get some new piping and re-route it better Quote
Mikeyallgood85 Posted September 25, 2013 Posted September 25, 2013 And the winning prize go to me lol :-P Quote
Hunty Posted September 25, 2013 Author Posted September 25, 2013 indeed it does haha prize is in the post ;) Quote
Mikeyallgood85 Posted September 25, 2013 Posted September 25, 2013 Cheers pal! Glad you got it sorted :-) Quote
carl1981 Posted October 23, 2013 Posted October 23, 2013 av got one for you then mikeyallgood85 my car is holding back aswell, when it idles it revs up ok, when I take it up the road it wont pick up at all pal, got told it might be map sensor, av change turbo ht leads could it be an air leak Quote
akyakapotter Posted October 23, 2013 Posted October 23, 2013 Un plug the lambda and see what happens mine is holding back between 2k and 3k due to a faulty lambda un plugged it and it's fine now Quote
