Dan_Henderson Posted September 22, 2013 Share Posted September 22, 2013 Ok lads/lasses wanting facts not opinions, is it ok to run a gt on td04 with rrfpr and fcd running 1.0 bar? The car will be used once or twice a month ?Would only use it til the funds allowed management and proper set up Quote Link to post Share on other sites
Phil Posted September 22, 2013 Share Posted September 22, 2013 yes. Phil Quote Link to post Share on other sites
russ78 Posted September 22, 2013 Share Posted September 22, 2013 as above ^^ short term should be ok if fueling is set up correctly,but management is the better way to go Quote Link to post Share on other sites
TurboTobz Posted September 22, 2013 Share Posted September 22, 2013 (edited) Management best however if they are well set up rrfpr and fcd's can run your car safely for years as has been proven by some, it's down to luck of the draw and the skill of the person who sets your fuelling Edited September 22, 2013 by TurboTobz Quote Link to post Share on other sites
Dan_Henderson Posted September 22, 2013 Author Share Posted September 22, 2013 Fueling would be set up professionally on a rolling road, would an updates fuel pump be advised? Quote Link to post Share on other sites
AdamB Posted September 22, 2013 Share Posted September 22, 2013 On 9/22/2013 at 4:37 PM, Dan_Henderson said: Fueling would be set up professionally on a rolling road, would an updates fuel pump be advised?Yep Quote Link to post Share on other sites
russ78 Posted September 22, 2013 Share Posted September 22, 2013 chances are your stock fuel pump is 15+ years old upgrading is always a better option, go for a 255lph TD or walbro and you'll have no worries Quote Link to post Share on other sites
Dan_Henderson Posted September 22, 2013 Author Share Posted September 22, 2013 Thanks for the help lads Quote Link to post Share on other sites
