Ollieh17 Posted September 22, 2013 Posted September 22, 2013 Basically got bored of my dumpvalve so have removed the vac hose to the dump valve and blocked it up. It chatters fine at low boost but at higher boost/rpm it sounds like air rushing out even with the throttle still open.Previously thought my turbo felt laggy and maybe going for chatter has revealed a leak?!?! Quote
TurboTobz Posted September 22, 2013 Posted September 22, 2013 put it back on and see if it gets rid of it, the dump valve could be leaking, what make is it? Quote
RobSR Posted September 22, 2013 Posted September 22, 2013 Itll be the DV leaking. If you want chatter remove the valve completely instead of just blocking the vacuum up. Quote
Ollieh17 Posted September 22, 2013 Author Posted September 22, 2013 Its a baileys.. Reconnected there is no air leaking noise. But still think the turbos laggier than it should be.. Maybe the DV Is the issue? Quote
TurboTobz Posted September 22, 2013 Posted September 22, 2013 baileys are renowned for leaking, remove it and blank it see if that changes it. Quote
Ollieh17 Posted September 22, 2013 Author Posted September 22, 2013 Guess thats why they are cheap!! Are there blanking plates for a glanza.. Did have a quick google Quote
TurboTobz Posted September 22, 2013 Posted September 22, 2013 Usually you just find something cylindrical andPop it in the hose and clamp it in place, you can buy proper ones Quote
