Darraghmh91 Posted September 24, 2013 Posted September 24, 2013 hows thing just wondering where id get hks pullys for my ep82 cheers lads Quote
Azz Posted September 24, 2013 Posted September 24, 2013 Not a chance fella, not even aware they made them for the 4E apart from the adjustable cam pulley.If anywhere I would try rhd Quote
Darraghmh91 Posted September 24, 2013 Author Posted September 24, 2013 sound anywhere online where youd get good lightweight purple pullys Quote
Azz Posted September 24, 2013 Posted September 24, 2013 Fensport do them but you have too either contact them about powdercoating them or get them done yourself Quote
pick1 Posted September 25, 2013 Posted September 25, 2013 Try tuning developments see if mike can help u out Quote
Darraghmh91 Posted September 25, 2013 Author Posted September 25, 2013 Sound ill try them and see what they can do .. Cheers lads hopwfully they have what i want Quote
Rock-Kick-Ass Posted September 25, 2013 Posted September 25, 2013 try here http://www.murraymotorsport.ie/ Quote
Darraghmh91 Posted September 25, 2013 Author Posted September 25, 2013 colt an arm and a leg in murray motorsport man i do be down with him a good bit have a set sorted already so this can be locked Quote
TurboTobz Posted September 26, 2013 Posted September 26, 2013 Aren't standard ones harmonically balanced? I recall reading of them causing issues Quote
AdamB Posted September 26, 2013 Posted September 26, 2013 Aren't standard ones harmonically balanced? I recall reading of them causing issues Harmonic dampers yes, and yes lightweight ones or more so ones that aren't damper pulleys on the crank can cause more load on the thrust washers, not much of a problem if you replace the bearing shells every so often though. Quote
TurboTobz Posted September 26, 2013 Posted September 26, 2013 Harmonic dampers yes, and yes lightweight ones or more so ones that aren't damper pulleys on the crank can cause more load on the thrust washers, not much of a problem if you replace the bearing shells every so often though. Thats the one, although I wouldn't fancy rebuilding bottom ends for the sake of a shitty pulley, different story if you were doing a race series or something and liked to overhaul every 'x' hours Quote
mattyD Posted September 26, 2013 Posted September 26, 2013 I heard that if there was enough interest in a part that it might be possible to have it made, not sure if that's a true fact and I imagine if it is, it will be very expensive! Quote
AdamB Posted September 26, 2013 Posted September 26, 2013 Thats the one, although I wouldn't fancy rebuilding bottom ends for the sake of a shitty pulley, different story if you were doing a race series or something and liked to overhaul every 'x' hours ACL recommend their bearing shells are changed every 30,000 Km anyway, but it depends how much power your running and what oil clearences you run as to what kind of service schedule you stick to. I was going to get ATI to make me up a custom lightweight crank damper pulley, but that's something I'll look into when I get closer to building the motor. Quote
TurboTobz Posted September 26, 2013 Posted September 26, 2013 ACL recommend their bearing shells are changed every 30,000 Km anyway, but it depends how much power your running and what oil clearences you run as to what kind of service schedule you stick to. I was going to get ATI to make me up a custom lightweight crank damper pulley, but that's something I'll look into when I get closer to building the motor. Realistically 30k km is not where we'd be hoping to rebuild the bottom end though, I guess it's just a figure to cover ACL's back. Sounds interesting, will make for some good reading when you get updating and into the building side. Best of luck! Quote
AdamB Posted September 26, 2013 Posted September 26, 2013 Realistically 30k km is not where we'd be hoping to rebuild the bottom end though, I guess it's just a figure to cover ACL's back. Sounds interesting, will make for some good reading when you get updating and into the building side. Best of luck! I agree, they say to replace them to maintain a good condition crank. I understand what their saying though, I would rather be replacing a set of shells that cost £80 than replacing a crank, especially the genuine 4ET crank which seem to be getting harder to find. Quote
TurboTobz Posted September 26, 2013 Posted September 26, 2013 I agree, they say to replace them to maintain a good condition crank. I understand what their saying though, I would rather be replacing a set of shells that cost £80 than replacing a crank, especially the genuine 4ET crank which seem to be getting harder to find. Yeah in that context it's a no brainer but when you consider the amount of work to change them then it's a bit of a killer lol. Quote
