Hi everyone ive got td94 kit with external wastegate.. the problem is thaf i have no idea which lines go where.. i know on my old ct9 kit thevac line goes from the bov to the intake.. buy on the new kit theres two nipples on the external wastegate.. one on the side and one on the top.. what do i do with these??
Noooo side port on the wastegate to the compressor housing, top one goes to you BC solenoid if you run one, if not leave it open. The other port on the BC solenoid then is T-pieced into the vac between the compressor housing and side port on the wastegate.
Edited by RobSR
cheers lads, so the one on the side goes into the compressor housing and the top one just leave it open? i dont want to use a bc yet as i will need a fcd. and if i want to use a bc then cut the vac between the compressor housing and side port on wastegate and add a T piece to the top of the wastegate with the controller. and for the bov just same as it is now, vac line from bov to inlet?
^ this basically ha.
It's the best diagram I could find on the net for fitting the set up when I was doin it and came from a Honda forum so that's why it's so detailed haha
haa love it. cheers man!
