Only reason to change to a MLS gasket is because it takes more abuse, its able to withstand more detonation before blowing.
Thickness varies the compression ratio, which imo is already too low for these engines. If it was me I would be using a 0.6mm gasket.
That's a good enough reason for me to get a mls gasket as I do give my car hell a lot of the time
But the thinnest mls I've found is 1.2mm
ECC do a wide range of MLS gaskets, from 0.6mm right up to 1.9mm I believe.
There's also the TRD which is 0.6mm but are now discontinued so will be hard to find.
Cometic is another option but I'm unsure on what thickness they come in.
Ok cheers I will have a look at ecc and see what they got
ECC 0.6mm probably a very good choice.
you can get a paseo 5e Hg from toyota which is MLS standard and its 0.5mm
will find the part number now.
EDIT
Part no. 11115-11090
Phil
Edited by Philm
Athena 1.2mm would be my choice.
i can understand this to a point, but the 'headroom' given by a 1.2mm hg will never be taken advantage off on stock internals (within the UK)
so if your staying td04 1bar, go 0.5mm with management (EMU will do)
Phil
