Hi, I bought a 5efe w/auto for my 1998 NP90(currently running a 1N). I have a problem regarding the ECU he gave me with the motor. It says '5A-FE 4A/T' Now, I presume that it is for a 5a-fe not 5e-fe and 4a/t probably refers to 4spd auto transmission. Engine was removed from a Corolla L-touring wagon.
I googled its number, 89661-1E020, and found out that that particular ECU was used for the AE110 sprinter and trueno. Is it possible that both engines used the same ecu? Thanks for your help
Are you 100% certain you got a 5e-fe? I can only recall 4e's being fitted to the corolla.
Edit: check the engine number stamped on the block.
Edited by chrisgreen1993
Some JDM corollas did get the 5E, maybe other markets too. I was looking at one ages ago on trade car view called a corolla II which had a 5E and 4WD, would have been beast turbo'd.
it is a 5Afe it turned out. still an enormous improvement over the 1N though.
JDM corollas had it as Daniel correctly stated; the rolla it was removed from is in fact a Japan import. So is my starlet. I dont remember diesel starlets sold new in Europe
Edited by cherrye10
