just got my RARB, whiteline adjustable, has 3 holes, which hole stiffens up the back end the most? it was used on the middle hole but was curious which is best to use, obviously too much rear grip is bad but wanna try the stiffest setting to see what its like
cool Im fitting it wednesday as Im spraying it at the moment, you know how whiteline products look like after a couple years lol! looking forward to seeing the results
The furthest out hole will be the softest setting, as you say mikey it has the most leverage further out so is easier to twist and hence softer.
Thought as much!
