EPnick22 Posted October 10, 2013 Posted October 10, 2013 whenever i start my car, fan comes on, it never used to do this when i had my old stock rad, now im using a half rad but still the same plug so whats changed? Quote
mikey4410 Posted October 10, 2013 Posted October 10, 2013 rad fan switch failed mine did same when i did conversion Quote
jayc-glanza17 Posted October 10, 2013 Posted October 10, 2013 ran fine in mine mate..you removed aircon?? and forgot to pin the plug?? Quote
Jamie5414 Posted October 10, 2013 Posted October 10, 2013 (edited) rad fan switch knackered as above, had this a few times and on different makes of car too. Edited October 10, 2013 by Jamie5414 Quote
EPnick22 Posted October 10, 2013 Author Posted October 10, 2013 where abouts actually is the fan switch? never really looked at it, and Jay the aircon was removed years ago before I have the car, its only since I swapped the rads over that its constantly on Quote
corofin12345 Posted October 10, 2013 Posted October 10, 2013 the fan switch/sensor is on the thermostat housing.. follow the bottom hose back from rad, its at the end of the hose on "thermostat housing" Quote
EPnick22 Posted October 10, 2013 Author Posted October 10, 2013 theres like 5 plugs there ahha you know which one it is? Quote
corofin12345 Posted October 10, 2013 Posted October 10, 2013 the fist one you come across at the end of the bottom rad hose Quote
EPnick22 Posted October 10, 2013 Author Posted October 10, 2013 if its the one with the green plug then I know which one youre talking about, ill have a look tomorrow Quote
corofin12345 Posted October 10, 2013 Posted October 10, 2013 this one http://i388.photobucket.com/albums/oo328/KELLYJGT/010-1.jpg Quote
EPnick22 Posted October 10, 2013 Author Posted October 10, 2013 yeah thats the one i was thinking of, cheers mate Quote
jayc-glanza17 Posted October 10, 2013 Posted October 10, 2013 (edited) isn't the green plug coolant temp sensor on the thermostat housing? Edited October 10, 2013 by jayc-glanza17 Quote
corofin12345 Posted October 10, 2013 Posted October 10, 2013 (edited) isn't the green plug coolant temp sensor on the thermostat housing? thats on the water housing.. the fan switch/sensor in on the thermostat housing.. the CTS has either 2 or 3 pins depending on the year/loom... Edited October 10, 2013 by corofin12345 Quote
corofin12345 Posted October 10, 2013 Posted October 10, 2013 (edited) its a '92 ep82 its the one i linked to you mate.. also may be worth checking to see if the connector for the A/C is still bridged... this would of been done when the A/C was removed.. link below shows this connector.. its located under or in front of the main fuse box in the engine bay.. it could of came loose when you were installing the new rad p.s. this only has to be done on GT turbos, not glanzas.. if this isnt bridged like below on GT's, the rad fan will run constant.. http://img824.imageshack.us/img824/3255/june006.jpg Edited October 10, 2013 by corofin12345 Quote
