as we all know standard FUEL CUT does come in at 12.3 psi which is 0.85 bar.
what does that mean the starlets run at normally so as to not hit fuel cut.
would it be 11.5psi or 12 psi
i am on a td04 so theres no boost creep
basically what does toyota make them run standard and would you guys run at to makesure ure getting the most power but not getting fuel cut please ?
Edited by mikey4410
Technically i dont think fuel cut is measured in a set psi. Its done as a voltage reading to the ecu so all cars are slightly different
