Sandham Posted October 16, 2013 Share Posted October 16, 2013 Hi, was just wondering whats the most pressure i can safely run on a td04 under fuel cut? Thanks Quote Link to post Share on other sites
russ78 Posted October 16, 2013 Share Posted October 16, 2013 if you mean boost pressure......... fuel cut is 0.85Bar so anything under this Quote Link to post Share on other sites
Sandham Posted October 16, 2013 Author Share Posted October 16, 2013 Ok thanks mate Quote Link to post Share on other sites
Sandham Posted October 20, 2013 Author Share Posted October 20, 2013 Just read on another thread that the td04 has more flow than a ct9 so will hit fuel cut at around 8psi?? Can anyone comfirm this as i was going to adjust my actuator to boost around 11psi after russ said that it will be ok to 0.85 bar..Dont want to blow the engine up though so would rather someone comfirmed or denied it?Thanks Quote Link to post Share on other sites
pick1 Posted October 20, 2013 Share Posted October 20, 2013 That's correct the td04 will flow more boost if u set the boost level right as in .8 it shouldn't creep although it can happen sometimes u won't blow your engine up by hitting fuel cut but it's not very nice and tried to throw u threw the windscreen just keep an eye on your boost gauge dude Quote Link to post Share on other sites
mikey4410 Posted October 20, 2013 Share Posted October 20, 2013 (edited) i run my td04 @ 10.5 psi and is flawlessand well done for not using a fcd by the way. and td04s dont creep at all,td04 for the win. Edited October 20, 2013 by mikey4410 Quote Link to post Share on other sites
Sandham Posted October 20, 2013 Author Share Posted October 20, 2013 (edited) Ok so if i set it and allow for a small amount of room it will be ok to run around 10/11psi? And yeah but i dont want to risk damaging anything for a small but of extra boost.Thanks! Really dislike fcd after removing mine, the car seems to run better without it. Ive got a emb sat here waiting but cant afford a map and im abit bored of 7psi Edited October 20, 2013 by Sandham Quote Link to post Share on other sites
mikey4410 Posted October 20, 2013 Share Posted October 20, 2013 as i just said above ,set for 10.5 psi.i want to be on the super safe side what u choose is up to you but the trade of for another psi in my eyes isnt worth hitting fuelcut. play it safe mate and enjoy the circa 165 bhp you will get from 10.5 psi done............. Quote Link to post Share on other sites
Sandham Posted October 20, 2013 Author Share Posted October 20, 2013 Yeah i have done mate, surely it will run more than 165 at 10.5psi? Quote Link to post Share on other sites
