PAUL7 Posted October 20, 2013 Posted October 20, 2013 got a subaru wagon with a td05 turbo and a spare td04 can these be put in a starlet? Quote
PAUL7 Posted October 20, 2013 Author Posted October 20, 2013 would you need to go forged with the td05?? Quote
russ78 Posted October 20, 2013 Posted October 20, 2013 (edited) now that's a well debated question, personally id say not much point using a TD05 on a stock engine as the gains are gonna be minimal under 1 bar but the lag will be quite noticeable over a TD04 but not saying you cant use a TD05 on a stock engine as many have and do...... Edited October 20, 2013 by russ78 Quote
Fozzie Posted October 20, 2013 Posted October 20, 2013 I think the TD04 is 'in its prime' around 1 bar (which suits a standard engine well) and kinda hitting its limits at 1.4 bar.TD05 shifts it all up, so it'll run best at over 1 bar (?) and go up to 1.6-1.7. Obviously you're pushing it by running it at over 1 bar on a standard engine, but under 1 bar, the TD05 likely won't really have woken up so it's going to be alot less driveable than the TD04 i.e a lot more laggy for no real gain.For bigger power on a forged engine then you'd be better with the TD05, but the TD04 would work well up to around 1.4 bar.That's the mega simple explanation anyway, I'm sure someone more technically proficient can give you extra detail if you want it! Quote
PAUL7 Posted October 20, 2013 Author Posted October 20, 2013 I think the TD04 is 'in its prime' around 1 bar (which suits a standard engine well) and kinda hitting its limits at 1.4 bar.TD05 shifts it all up, so it'll run best at over 1 bar (?) and go up to 1.6-1.7. Obviously you're pushing it by running it at over 1 bar on a standard engine, but under 1 bar, the TD05 likely won't really have woken up so it's going to be alot less driveable than the TD04 i.e a lot more laggy for no real gain.For bigger power on a forged engine then you'd be better with the TD05, but the TD04 would work well up to around 1.4 bar.That's the mega simple explanation anyway, I'm sure someone more technically proficient can give you extra detail if you want it!perfect lol! mines is running with the ct12, what is better ct12 or a td04? tdo5 sounds like too much lag Quote
Fozzie Posted October 20, 2013 Posted October 20, 2013 I think it depends what you mean by better mate? I'm not an expert on the CT12, but as a stab in the dark I would expect the TD04 to spool slower but pull harder? Hopefully someone with some extra experience of the 2 can advise though! Quote
mikey4410 Posted October 20, 2013 Posted October 20, 2013 yea i would tend to agree with the td04 spool slightly slower than a ct12 but td04 will have more power with more psi compared to ct12 just get a td04 and enjoy.cheap turbos to pick up Quote
