Cheers guys had a quick double check there's nothing on the casing in the fuse box in the engine bay or in the fusebox below the steering wheel.
Maybe been a sticker and been removed possibly any of you guys want to check yours to see if yours are the same ?
just take the aircon out :D
L O L simple way around it
I would check BUT 1) i have a glanza, and 2) my car isnt here :D
Put a post up in the general section saying FAO GT Owners.. that'll grab there attention
i don't have aircon. The pump is there for the power steering belt but the unit that sits in front of the rad has been removed and the hoses for it going into the bulk head have been sawed off.
The reason i'm asking as i have a high idle and ran the diagnostic check and got the error code 51 sayin the aircon switch is on so it must be the aircon electrics and if i knew the correct fuse then i can disable it.
