BoostJunkie Posted October 25, 2007 Share Posted October 25, 2007 as above says anyone know which fuse is for the a/c on my 92 gt. Quote Link to post Share on other sites
Glanza_Ragger Posted October 25, 2007 Share Posted October 25, 2007 It should be listed on youre fuseboard diagram under the dash bud? Quote Link to post Share on other sites
BoostJunkie Posted October 25, 2007 Author Share Posted October 25, 2007 are you meaning on the back of the cover on the fuse box under the dash as first place i checked nothing on it or somewhere else ? Quote Link to post Share on other sites
SiCaln Posted October 25, 2007 Share Posted October 25, 2007 hmm wudv thought it was there if not in engine box of fuses? Quote Link to post Share on other sites
BoostJunkie Posted October 25, 2007 Author Share Posted October 25, 2007 Cheers guys had a quick double check there's nothing on the casing in the fuse box in the engine bay or in the fusebox below the steering wheel. Maybe been a sticker and been removed possibly any of you guys want to check yours to see if yours are the same ? Quote Link to post Share on other sites
BoostJunkie Posted October 26, 2007 Author Share Posted October 26, 2007 nobody have a clue then even some-one with an n/a check to see where the fuse is in theirs,it may help. Quote Link to post Share on other sites
vineygt Posted November 2, 2007 Share Posted November 2, 2007 just take the aircon out Quote Link to post Share on other sites
Glanza_Ragger Posted November 2, 2007 Share Posted November 2, 2007 vineygt said: just take the aircon out L O L simple way around itI would check BUT 1) i have a glanza, and 2) my car isnt here Put a post up in the general section saying FAO GT Owners.. that'll grab there attention Quote Link to post Share on other sites
BoostJunkie Posted November 2, 2007 Author Share Posted November 2, 2007 vineygt said: just take the aircon out i don't have aircon. The pump is there for the power steering belt but the unit that sits in front of the rad has been removed and the hoses for it going into the bulk head have been sawed off.The reason i'm asking as i have a high idle and ran the diagnostic check and got the error code 51 sayin the aircon switch is on so it must be the aircon electrics and if i knew the correct fuse then i can disable it. Quote Link to post Share on other sites
