Hi. Ive just bought a forged 5e engine and in the process of buying a td05 turbo. What do people think of this ie. Power produced, lag, boost pressures? All opinions please.
Cheers
Its a good combo, pretty much the same sort of combo as a 4e + td04.
You'll probably make like 340-350bhp at 1.6 bar ish, depending if its the normal 16g unit.
Lag will be the same as 4e + td04 combo, 1 bar around the 3300ish mark depending on compression ratio and map. Isn't that td05 a hybrid? I thought it was but may have been reading something else haha.
Dont run 1bar to run it in lol. No boost for the first couple of miles, but lots of revs. Then start introducing a little bit of boost so the bores dont glaze over.
ive ran a 5e td05 16g for over 5 years, before that i went through a td04 and 2 vf28's which was FAR better for a fast road car but as i track mine ive since gone td05-20g.
  • 3 weeks later...
I'm going down the same route I have a fully forged 5e and was going to go td05 then the vfs caught my eye? Is a td05 not only capable of 290ish? Before the turbo starts stressing?
td05-16g from an impreza can flow upto 320-340 on a 4e, but all down to a decent ECU and a good map.
at 1.5bar on a td05 you should with a okish tune see from 290 to 300bhp area..
but td05s can run 1.7 if you want a power figure, and then ran a little less boost on road for turbo reliability.
1.5 is good boost for a td05, 1.2bar is minimum it likes otherwise you may as well go smaller turbo..
l
Emanage ultimate, td05-18g 311bhp@1.5bar
Was rather laggy though, I did a fith gear pull from 30 against my mate's vxr over a mile and he nailed me simply because of lag BUT when it kicks in Oushh it was good.
Needless to say I'm a lag whore
but td05s can run 1.7 if you want a power figure, and then ran a little less boost on road for turbo reliability. What's difference between 16g and 18g?
l
What's the difference between 16g and 18g
  • 3 weeks later...
5th gear is pritty poop but meh you just have to change more :thumbsup:
the lag is not that bad tbh when it kicks in its all worth it! :yahoo:
