Kingcarr Posted October 23, 2013 Posted October 23, 2013 Hi guys, Slight issue with the engine management light coming on when I pull off, as soon as I'm near neutral pressure (neither boost or vac) the EML comes on. I've used both a BLITZ Access ECU and a standard ECU and they both do it! I've done a diagnostic and error 34 ( boost pressure sensor) comes up, any ideas? Cheers, Nath Quote
TrisK Posted October 23, 2013 Posted October 23, 2013 Map sensorCheck vacuum lines and the filter to itThen see if you can borrow a mates sensor itself or something Quote
Kingcarr Posted October 23, 2013 Author Posted October 23, 2013 Is that the one on the firewall? I don't think mine has a filter? Is there a way of metering it to check the output? Or cleaning it if it isn't filtered? Quote
Kingcarr Posted October 24, 2013 Author Posted October 24, 2013 No mate, no one local available til the weekend! Quote
Kingcarr Posted October 26, 2013 Author Posted October 26, 2013 Tried a new hose and without the filter mad still getting the EML, anyone got a sensor? Quote
