kash_b Posted October 26, 2007 Posted October 26, 2007 hi i have a problem with a glanza i had changed the oil and oil filter today, soon after all of this i had taken it for a drive and as soon as the turbo is about to kick in the car just looses power . i have checked the engine bay and cannot see anything wrong also when you rev the car and let go you can hear the turbo spinning as if its dry! any help please cheers Quote
paul w Posted October 27, 2007 Posted October 27, 2007 Check all hoses then check em again and again! Or it may be the rubber insert that goes around the turbo intake thats been sucked in. seen that happen before. Quote
WallaceGlanza Posted October 27, 2007 Posted October 27, 2007 You may have blocked off the oil feed to the turbo somehow, this happened on mine and the turbo didn't last long. Did you get anything contaminated with the oil? It may have some crap in it which has blocked a line.Also what did you take off when changing the filter? if you had the air intake off then it probably is just as Paul suggested.I'd try to get it sorted asap. Quote
kash_b Posted October 30, 2007 Author Posted October 30, 2007 cheers guys i been on the car today and found that the oil filter was different compared to the one i put on so i put the original one back on and the oil pressure was back ;) now the turbo is only boosting to 0.8bar and does not feel as quick as it did when it was boosting at a bar u think the turbo is finished?? cheers Quote
paul w Posted October 30, 2007 Posted October 30, 2007 You say different oil filter?In what way,make or car it's suited to?The 4E engines all use the same filter. Quote
kash_b Posted October 30, 2007 Author Posted October 30, 2007 i think the original one had a valve isn't it and the uk one which i got did not which had stopped the oil pressure has any one else had this similar problem Quote
paul w Posted October 31, 2007 Posted October 31, 2007 Go get one from toyota and fit that! That means it's the right one no question then. ;) Quote
