I thought I knew about plugs until I found this. Mine were always a nice tan colour and Id pull no.4 every now and again to watch for overheating or oil burning (mostly oil burning)
Now Ive the bigger tb on its a clean white plug though the base ring is black. I cant see the other marks yet though
  • 4 weeks later...
Half the vid is incorrect, for example ground strap does not indicate heat range but spark lead. Anyway inspecting a spark plug is the most accurate way of telling how good a tune is and this is not jus' WOT tune, but all engine conditions. More accurate then a afr, lead or egt feedback in my opinion.
