dangeestarlet Posted November 3, 2013 Posted November 3, 2013 Going to cover my ugly material on my n/a door cards tommorow with some black suede, tips and instructions needed, thanks Quote
JDMfreak Posted November 3, 2013 Posted November 3, 2013 why not fit 96 or 98 spec door cards do the electric window conversion aswell ive done it on my N/A starlet Quote
ep91 nicky Posted November 3, 2013 Posted November 3, 2013 use some clothes clips to keep the material tight when u bend it over the door card Quote
dangeestarlet Posted November 3, 2013 Author Posted November 3, 2013 why not fit 96 or 98 spec door cards do the electric window conversion aswell ive done it on my N/A starlet saving weight ;) naa only kidding, I will later on but for now il just cover them Quote
dangeestarlet Posted November 3, 2013 Author Posted November 3, 2013 use some clothes clips to keep the material tight when u bend it over the door card ok thanks I'm gunna use some spray glue aswell , the only part I'm stuck on is were the material is stuck on to the plastic on the door card, il get some pics up in a min Quote
JDMfreak Posted November 3, 2013 Posted November 3, 2013 saving weight ;) naa only kidding, I will later on but for now il just cover them Quote
dangeestarlet Posted November 3, 2013 Author Posted November 3, 2013 if I just cut material to shape and stick it on over time it will peel back as the material looks like its been pressed on the plastic Quote
bucketep91 Posted November 3, 2013 Posted November 3, 2013 Just cover that part aswell. If u ise spray glue, hold the can about 18 inches away to keep it dry. If u spray too close it will go on wet and come theough the material. Buy the glue from a carpet place, the pound shop and b&q stuff is pish Quote
dangeestarlet Posted November 3, 2013 Author Posted November 3, 2013 Ok thanks , I just seen a thread on here were they used black fabric spray so might see if I can buy some of that from somewhere tommorow Quote
ep91 nicky Posted November 3, 2013 Posted November 3, 2013 When a done mine a wrapped the full door card and just bought accustic carpet Quote
cherrye10 Posted November 11, 2013 Posted November 11, 2013 why not fit 96 or 98 spec door cards do the electric window conversion aswell ive done it on my N/A starlet done that too. straight swap. interior already feels more 'habitable' but you'll have to replace all plastic panels to match the dark gray of the glanza Quote
cherrye10 Posted November 12, 2013 Posted November 12, 2013 thought only the glanza came with power windows Quote
Flynn Posted November 12, 2013 Posted November 12, 2013 thought only the glanza came with power windows Both my SR's have had them. Quote
Chris Green Posted November 13, 2013 Posted November 13, 2013 (edited) Have you any tips for doing that Flynn? What way did you do the edge closest to the hinges? Edited November 13, 2013 by chrisgreen1993 Quote
