TurboTobz Posted November 4, 2013 Posted November 4, 2013 Heat it up with oxy acetylene before proceeding to startlol, check usuals plugs leads dizzy, check plug recesses for water that often collects there Quote
Tobyb94 Posted November 4, 2013 Author Posted November 4, 2013 Got coil pack on mine plugs seem to be ok Quote
Tobyb94 Posted November 4, 2013 Author Posted November 4, 2013 Yer been fine up an till few days ago Quote
daniel_g Posted November 4, 2013 Posted November 4, 2013 Spray the area with a bit of water, fine spray dont go mental, see if you can see it arc'ing, ie, blue lightening. Might have a slight nick in a lead or something. Quote
TurboTobz Posted November 4, 2013 Posted November 4, 2013 Yer been fine up an till few days ago May have a coil down then also Quote
Tobyb94 Posted November 4, 2013 Author Posted November 4, 2013 Will do fine once started just on start up for a few seconds then clears Quote
