tatep82 Posted November 12, 2013 Posted November 12, 2013 anybody got any tips to how to help me rotate my turbo shes a bit seized!its a td04 and need to rotate her so shes out the way of my oil filter thanks matt Quote
TurboTobz Posted November 12, 2013 Posted November 12, 2013 Should be some bolts or similar around the inside edge, remove them and any clamps, then a large cir clip for the compressor housing, and the v band style strap in the middle, a little bit of even tapping with a hammer around the exhaust side and it should come away, be careful that you don't attack one side more than the other and jimmy it off otherwise you may damage the fins. Quote
TurboTobz Posted November 12, 2013 Posted November 12, 2013 theres 2 locating pins on the comp housing side, the one I rotated needed one to be filed away and one was removed by popping it out with a pair of pliers and some force. Quote
akyakapotter Posted November 12, 2013 Posted November 12, 2013 Lots and lots of wd40 I soaked mins for about a week before I even tried rotating it and pulled the locating pins out with some mole grips Quote
tatep82 Posted November 13, 2013 Author Posted November 13, 2013 ill keep putting the wd on, and have a go tom night see if I have any look Quote
