Hi all,
I bought the car cheap as it needed a lot of TLC.
Was running a smokey CT9 at 1bar.
The plan was to put a TD04 on as cheaply as possible to see if I catch the bug and if I do replace the manifold with a WEPR item later.
Here's a few pics of the progress :)
Posted Image
Posted Image
Posted Image
Posted Image
Budget build FTW!!
People forget these where cheap cars back in the day never intened for 10k++++ builds be good to see some normality in a starlet for a change (not that a TD04 GT can be called "normal" by any stretch of the imagination!)
Best of luck with it lad
Cheers lads :)
The manifold is a Toyosports which I won on Shebay for £76 for the kit :)
I know about these manifolds so I've braced the hell out of it!
Modified it to convert it to external wastegate, not keen on internal gates ;)
Used 12mm solid stainless round bar from the head flange and bridges across to the turbo flange.
Good thing is where I've added an external gate there's a lot more structural rigidity in the collector
Can i buy that? Or would i need to fabricate that?.. Any links?
You can buy the stock stainless bar no problem but all the rest of it is custom fabricated unfortunately.
Any good fabricator will be able to sort it for you :)
Good you take a close shot of the bracing? Can use that to show my fabricator!
I'll get a pic for you mate, the pic only has one brace in it as I didn't take any after I put the wastegate pipe in.
Gives you an idea of what to do though :) , it's pretty self explanatory fella :)
Just given the car a good run, all seems good apart from the wastegate having a 0.6 bar spring when it was supposed to be 1 bar :( .
Good news is it feels as quick at 0.6 bar on the TD04 as it did on 1 bar with the CT9 :)
Boost controller and then I'll be happy!!!
Edited by ROTABOOST
Just given the car a good run, all seems good apart from the wastegate having a 0.6 bar spring when it was supposed to be 1 bar :( . Good news is it feels as quick at 0.6 bar on the TD04 as it did on 1 bar with the CT9 :) Boost controller and then I'll be happy!!!
Nice one lad you loving tdo4?
How would you modify a manifold and weld a flange to make it externally wastegated?
Yes mate if recommend it to anyone, totally changed the car :D .
It's pretty simple if you can fabricate bud, just a case of notching the recess for the wastegate take off into the collector of the manifold, then buying the suitable tube to supply the wastegate and it's just a case in welding on the flanges that come with the wastegate into the tube.
If you are confident at welding and fab it's a pretty simple task :)
