Ollieh17 Posted November 18, 2013 Posted November 18, 2013 Had a suspicion my glanza was running rich and using more fuel than necessary. Bought a replacement and went to fit it, and found the lambda switch had snapped at the wire coming from the ecu. Instead of re-wiring the standard plug back into position i crimped the wire from ecu to the lambda. However i'm not sure the lambda is working properly still, what are my options to find out? Suppose its either air/fuel check or take it to a garage? Quote
Zeldoz Posted November 20, 2013 Posted November 20, 2013 Buy a replacment from a guy breaking. Seen a few go for £20 on Facebook and here! Quote
Zeldoz Posted November 20, 2013 Posted November 20, 2013 Did the wire come out the plug your plugging your new one into? Didn't fully read your question sorry lol Quote
Ollieh17 Posted November 20, 2013 Author Posted November 20, 2013 The whole plug snapped off at the wire to the ecu Quote
akyakapotter Posted November 20, 2013 Posted November 20, 2013 Should be fine crimped I replaced my lamba and it's crimped much better on fuel now Quote
Ollieh17 Posted November 20, 2013 Author Posted November 20, 2013 Really not sure if the crimps have worked, don't seem to be seeing an increase in mpg? May re-crimp them this weekend and see. Quote
Turk Posted November 25, 2013 Posted November 25, 2013 Doesnt sound like a wire problem. I think your sensor might have gone. How old is the kit? Quote
Ollieh17 Posted November 27, 2013 Author Posted November 27, 2013 it has a brand new sensor in it, have recrimped it again as before it wasn't the best. now to see if it makes any difference Quote
karl. Posted November 27, 2013 Posted November 27, 2013 it has a brand new sensor in it, have recrimped it again as before it wasn't the best. now to see if it makes any difference Have you a link to the one you bought? Want to replace mine before the fueling is setup just to make sure its ok. Quote
Ollieh17 Posted November 27, 2013 Author Posted November 27, 2013 http://www.ebay.co.uk/itm/120523868606?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2648 Quote
akyakapotter Posted November 27, 2013 Posted November 27, 2013 (edited) That's a cheap sensor I had a cheap one lasted about a year before it died replaced it with one from td now good as gold Edited November 27, 2013 by akyakapotter Quote
Turk Posted November 28, 2013 Posted November 28, 2013 (edited) As said dont buy cheap lambda. They fail and arent very accurate Edited November 28, 2013 by Turk Quote
