ryan22laird Posted November 30, 2013 Posted November 30, 2013 Hi guys just got myself a new glanza last month the engine was blown up so a got a new engine and fitted it today this engine was meant to be out a glanza but there was a lot of things different such as connector plugs fuel rail water pump and power steering bracket all this was different I had to take all these parts off my blown engine so now all this was done started the car up wasn't running good at all was idling high and low sorted that problem out car was ticking over and reving good went to take it a blast and it wouldn't go past 2000rpm wanted to cut out on me but if a put my foot on the clutch it revs right up Quote
TurboTobz Posted November 30, 2013 Posted November 30, 2013 check map sensor vacuums and wiring, look for vac leaks Quote
