Ollieh17 Posted December 3, 2013 Posted December 3, 2013 Changed the turbo round last week and have had a lot of problems! The last problem left is a stud has and bolt for the manifold has had it and needs replacing. Because of the missing stud on the corner of the manifold it is blowing and the car sounds horrible. Also the car isn't boosting AT ALL. Quote
Gainzy Posted December 3, 2013 Posted December 3, 2013 Sounds like a major pain in the ass, you will need a new gasket which mean taking the mani off again, if your after an oil line you also need a gasket for that....just go balls out for that td04 kit you want or else your just gunna throw more money getting this right.. Quote
Zeldoz Posted December 3, 2013 Posted December 3, 2013 Sounds like a major pain in the ass, you will need a new gasket which mean taking the mani off again, if your after an oil line you also need a gasket for that....just go balls out for that td04 kit you want or else your just gunna throw more money getting this right.. Exactly why i didn't bother fixing my CT9 boost creep issues, fuel cut.. endless issues. Knew would've been a money pit! TD04 it Ollie Quote
Ollieh17 Posted December 3, 2013 Author Posted December 3, 2013 Gasket is brand new so no way of using it again? or will the blow f**k it up? I can't afford to go td04 at the moment . Also want to get the car up to scratch handling wise before I td04 which will put it off longer. I don't want a car thats quick in a straight line but handling isn't the best. Coilovers, struts and upgraded brakes first Quote
WallaceGlanza Posted December 3, 2013 Posted December 3, 2013 Gasket is brand new so no way of using it again? or will the blow f**k it up? I can't afford to go td04 at the moment . Also want to get the car up to scratch handling wise before I td04 which will put it off longer. I don't want a car thats quick in a straight line but handling isn't the best. Coilovers, struts and upgraded brakes first Very sensible being patient and doing it properly. If the gasket is a decent one - not the cheap toyosports type ones then it should be ok to re-use, just get a new stud and you'll be good to go. Quote
Ollieh17 Posted December 3, 2013 Author Posted December 3, 2013 (edited) I want to do my first bit of track time net year. Coilovers, nice bucket seats, struts and roll bars and goo brakes will benefit me more than faster straightline speed!! Gasket is a racespec performance one from ebay? Edited December 3, 2013 by Ollieh17 Quote
Ollieh17 Posted December 4, 2013 Author Posted December 4, 2013 replacement stud and bolt should be here today...praying this fixes it and car goes back to how it was Quote
Zeldoz Posted December 4, 2013 Posted December 4, 2013 replacement stud and bolt should be here today...praying this fixes it and car goes back to how it was Hope it does mate! Then your be all smiles.. Dont give up! Quote
Gainzy Posted December 4, 2013 Posted December 4, 2013 (edited) Wack abit gasket sealer on that may help don't back out now it's part of the journey of built not bought if somethings fucked it's time to say right next time am doing it properly all in just learn from it the amount of times I have nearly give up mine is endless! Put your cash into getting it running sweet least you can get coilovers on finance, it's gunna be gash weather soon so a tdo4 is useless for the next 4 months. Aim that for summer Edited December 4, 2013 by Gainzy Quote
Ollieh17 Posted December 4, 2013 Author Posted December 4, 2013 So basically got the stud seems to screw in fine, then when i tighten the bolt up the stud then just spins. I think i have fucked the thread which the stud screws into. Massive headache, no idea how im gonna get it sorted. Quote
Gainzy Posted December 4, 2013 Posted December 4, 2013 Tap n die it..is zeldoz not selling a full kit soon? It might be worth just splashing out on that ask him to sell all as one so you don't have to mess around with gaskets etc if I remember that turbo n that had low miles, tap n die is a piece of cake to use, have a look into it Quote
Zeldoz Posted December 4, 2013 Posted December 4, 2013 Wack abit gasket sealer on that may help don't back out now it's part of the journey of built not bought if somethings fucked it's time to say right next time am doing it properly all in just learn from it the amount of times I have nearly give up mine is endless! Put your cash into getting it running sweet least you can get coilovers on finance, it's gunna be gash weather soon so a tdo4 is useless for the next 4 months. Aim that for summer Where finance, WHEREEE? Quote
Ollieh17 Posted December 4, 2013 Author Posted December 4, 2013 Pretty sure my turbo and everything else is fine.. I hope so anyway. I probably have a mate who can do it. Longer with no car:( Quote
Gainzy Posted December 4, 2013 Posted December 4, 2013 Where finance, WHEREEE?Up in the northeast they can get lots of goodies and it doesn't have to be set payments http://www.revolution247.com/ Quote
Ollieh17 Posted December 4, 2013 Author Posted December 4, 2013 Step dad can sort out tapping it..just gotta take everything off again. Wish i could replace it with a td04 this time haha Quote
Ollieh17 Posted December 5, 2013 Author Posted December 5, 2013 they don't have coilovers really can't be bothered to take everything apart again, is it easy enough to take the manfiold off leaving turbo in place and supporting it while tapping?Or is it one of those shortcuts that is gonna take earlier. Quote
