Hello all,
Have been looking online as I am thinking of another starlet as I didn't manage to get the full fun out of my first one due to job loss.
Anyway I have been looking online and seen a couple. I am mainly after a MK1 as I prefer them to the others I have seen one online that looks interesting but need to know a few things before I do. I know a few things about these cars but not about this turbo set up. It is running a TD05 what is the difference between this ant the TD04 as I know that is the most common upgrade. It does have quite a lot of upgrades to it which make me a bit nervous as it has done 109 miles without a new engine by the sounds of things the spec is below if you could tell me what you think I would be grateful.
TD05 running safe 0.9bar boost
Tomz tecs ecu
HKS actuator
Toyo sports manifold
Autobahn88 front mount
FPR
Uprated injectors unknown make
Uprated clutch
Civic rad
Manual boost controller
Japspeed full exhaust
Toad cat1
A TD05 is bigger than a TD04, it will spool later but is capable of more power.
Whether you need or want a TD05 is up to you and depends on your power goals, I've been out of the Starlet scene for a while so can't remember exact figures but basically if you're only aiming for just over 200bhp then a TD04 is fine, however if you're aiming for big power then stick with the TD05.
Edited by ste91
Thank you for that buddy I am grateful. From what he has put in his add the car is kicking out blue smoke so that would be the seals gone in the turbo right. I know there can be other courses but that is the most common.
So I can read the car gets smoky on boost but he has a new TD05 turbo that just needs to be fitted I would say fit it then see if it goes. If it is not the turbo what else could course that?
