Burt-21 Posted December 15, 2013 Posted December 15, 2013 So here it is i changed the headgasket on my ep91 put it back together now the temp don't go up when I'm driving but at a stand still it go to quater way where as it used to go half way if this ok or not Quote
Burt-21 Posted December 15, 2013 Author Posted December 15, 2013 Well it's opening fine at 72 degrees or something round there but I don't under stand why it was half way now it isn't or it's under the line when I drive the heater work fine so I don't see why it's stay so low Quote
Zeldoz Posted December 15, 2013 Posted December 15, 2013 You sure it's not a faulty needle? Bottom rad hose warm? Quote
Burt-21 Posted December 15, 2013 Author Posted December 15, 2013 Rad hose is fine it was all fine till I changed the head gasket then run a lot cooler but still get hot air coming throught the heatera Quote
Zeldoz Posted December 15, 2013 Posted December 15, 2013 Someone will drop in with more knowledge than me soon enough. Seems odd! Quote
Burt-21 Posted December 16, 2013 Author Posted December 16, 2013 No it wasn't over heating but there was a crack round one of the manifold studs so I had to change the head to stop it blowing Quote
Mad Mike EP82 Posted December 16, 2013 Posted December 16, 2013 Broken wire going to sensor maybe? Quote
Burt-21 Posted December 16, 2013 Author Posted December 16, 2013 Wires are all fine checked them Quote
Ismail K Posted December 16, 2013 Posted December 16, 2013 I had the same problem it was the thermo. Quote
Burt-21 Posted December 17, 2013 Author Posted December 17, 2013 I have one that opens at 82 I will try it at the weekend and way would it be not opening fully or something Quote
Dan Barnes Posted December 17, 2013 Posted December 17, 2013 Sounds like thermostat to me mate my gt done it Quote
corofin12345 Posted December 17, 2013 Posted December 17, 2013 is there heat coming through the heaters in the car when driving... ? it sounds like a faulty thermostat.. reason why temp is dropping while driving.. Quote
Burt-21 Posted December 21, 2013 Author Posted December 21, 2013 Yea there is heat when driving and while still but I can on have my heater on the window or the whole car steams up even tho there's heat Quote
zurgieSR Posted December 28, 2013 Posted December 28, 2013 thermo, mine done this a few months ago. new one cured it. Quote
