Hi guys,
Just bought a starlet ep82 a month ago and im very happy only i have a little problem!!
I noticed the other day that my coolant was way below the minimum mark so i checked under the radiator cap and i couldnt see any in there too. I filled up the bottle top half way and seemed fine. After a motorway drive i pulled in and it was coming out of the overflow everywhere! Caarried on driving and it was fine staying at a constant temprature. I pulled up into a garage and after being on tickover for a whiule it was really coming out everywhere again. I really dont know whats wrong with it and i dont know if its bad or not! Any help would be greatly apreciated. Thanks :)
welcome to the club mate,
i dont know if im reading you right but why did you not just fill the raidiater, regardless it does not sound normal
Yer i realised after i should have filled it up there but i had to drive it to get some water and didnt want to take the cap of the radiator while it was hot! Just seems a bit weird, i check it when its cold and its low and when its hot its also low and then it randomly overflows and the bottle is full again for a while and then it dissapears!!
HELPPPPPP!!
HELPPPPPP!!
If it is comming out of your radiator cap then you may need a new radiator cap
This happened in my old Crx i flushed the system and got a new cap and it was all fine again
Welcome along
Something tells me your head gasket is on its way out, but I'm no professional!
That is possible.
The loss of water on mine was due to the water pump being on the way out aswell
May be worth checking that out for leaks
Hello again, Ive had the rad cap replaced and also had the system flushed and refilled about 5days ago and no problems yet so lets just hope it stays that way!! Thanks again for the welcome guys! :(
