starlet86 Posted November 12, 2007 Share Posted November 12, 2007 Hi guys,Just bought a starlet ep82 a month ago and im very happy only i have a little problem!!I noticed the other day that my coolant was way below the minimum mark so i checked under the radiator cap and i couldnt see any in there too. I filled up the bottle top half way and seemed fine. After a motorway drive i pulled in and it was coming out of the overflow everywhere! Caarried on driving and it was fine staying at a constant temprature. I pulled up into a garage and after being on tickover for a whiule it was really coming out everywhere again. I really dont know whats wrong with it and i dont know if its bad or not! Any help would be greatly apreciated. Thanks Quote Link to post Share on other sites
Guest Enzo Posted November 12, 2007 Share Posted November 12, 2007 welcome to the club mate, i dont know if im reading you right but why did you not just fill the raidiater, regardless it does not sound normal Quote Link to post Share on other sites
starlet86 Posted November 12, 2007 Author Share Posted November 12, 2007 Yer i realised after i should have filled it up there but i had to drive it to get some water and didnt want to take the cap of the radiator while it was hot! Just seems a bit weird, i check it when its cold and its low and when its hot its also low and then it randomly overflows and the bottle is full again for a while and then it dissapears!!HELPPPPPP!! Quote Link to post Share on other sites
Sean_GT Posted November 12, 2007 Share Posted November 12, 2007 starlet86 said: Yer i realised after i should have filled it up there but i had to drive it to get some water and didnt want to take the cap of the radiator while it was hot! Just seems a bit weird, i check it when its cold and its low and when its hot its also low and then it randomly overflows and the bottle is full again for a while and then it dissapears!!HELPPPPPP!!If it is comming out of your radiator cap then you may need a new radiator capThis happened in my old Crx i flushed the system and got a new cap and it was all fine again Quote Link to post Share on other sites
Sparky Posted November 12, 2007 Share Posted November 12, 2007 Welcome to UKSC People are here to help so hope you get the problem sorted asap Quote Link to post Share on other sites
muddyell Posted November 13, 2007 Share Posted November 13, 2007 Nice advice there sparky boy Oh yea welcome to the club mate Quote Link to post Share on other sites
starlet86 Posted November 13, 2007 Author Share Posted November 13, 2007 OK i will give anything a try to sort it! Thanks for the welcome people and for the help! Quote Link to post Share on other sites
Idrees Posted November 13, 2007 Share Posted November 13, 2007 Welcome alongSomething tells me your head gasket is on its way out, but I'm no professional! Quote Link to post Share on other sites
Sean_GT Posted November 14, 2007 Share Posted November 14, 2007 Idrees said: Welcome alongSomething tells me your head gasket is on its way out, but I'm no professional!That is possible.The loss of water on mine was due to the water pump being on the way out aswellMay be worth checking that out for leaks Quote Link to post Share on other sites
Nanglebadger Posted November 15, 2007 Share Posted November 15, 2007 welcome along to UKSC! hope u get your problem fixed up!Phil. Quote Link to post Share on other sites
Jozinobi Posted November 15, 2007 Share Posted November 15, 2007 Welcome to the site mate.Hope you get your starlet sorted.Joz Quote Link to post Share on other sites
starlet86 Posted November 19, 2007 Author Share Posted November 19, 2007 Hello again, Ive had the rad cap replaced and also had the system flushed and refilled about 5days ago and no problems yet so lets just hope it stays that way!! Thanks again for the welcome guys! Quote Link to post Share on other sites
Sparky Posted November 19, 2007 Share Posted November 19, 2007 Good stuff mate Quote Link to post Share on other sites
briggers Posted November 19, 2007 Share Posted November 19, 2007 so your not meant to fi/ll it up in that white plastic bottle on he left hand side your meant to fill it up in the actual radiator cap? Quote Link to post Share on other sites
starlet86 Posted November 20, 2007 Author Share Posted November 20, 2007 Fill it up at the radiator mate not the cooling bottle. I heard it can do your headgasket if you do it in the bottle but could be a rubbish!! Quote Link to post Share on other sites
