I have seen some intercooler kits with the BOV on the 'Hot Pipe'
And see with the BOV just before the intake....
What's the difference? If any?
Thanks,
Andy
Thanks,
Andy
The theory of it says that BOV should go as close to the butterfly in the throttle body as possible
Im pretty sure GoldenVTR aka Dan is your man for this.. he has experimented both ways (lol)
I think it makes little to no difference.
if you really want to avoid comp surge run one either side :)
Phil
Edited by Philm
Okay thanks mine is currently on Hot Side & I want to change to 'Short Route' and the kits I look at are on the Cold/Intake side!
Does anyone know where I can get separate pipes or will I have to buy a set?
Cheers
Cold side, then reroute so that the blown off air comes into the intake before the turbo. Less annoying sound and less lag when changing gears or similar. Well, had a read around for half an hour and that's how it's the only legal way in germany but also the most favorable. Especially on drag or track driving with many gear changes.
