Japscrapno1 Posted December 23, 2013 Posted December 23, 2013 Are ordinary starlet alternator/water pump belts the same? As mine has just snapped and need a replacement quick before Boxing Day:/ Quote
Ollieh17 Posted December 29, 2013 Posted December 29, 2013 mines snapped too?? are standard starlet ones okay? Quote
Zeldoz Posted December 29, 2013 Posted December 29, 2013 Yes 923 will fit 4xx-923 fits I changed mine recently Quote
TurboTobz Posted December 29, 2013 Posted December 29, 2013 Yeah efes fit fine use them when you remove the ac pump Quote
Ollieh17 Posted December 30, 2013 Posted December 30, 2013 i replaced the power steering belt when i removed ac. But the alternator and water pump is separate no? Quote
ryan lang Posted December 30, 2013 Posted December 30, 2013 air con pump runs off the same one as the power steering pump. alternator is a different belt, but it is the same as the 4efe belt Quote
Zeldoz Posted December 30, 2013 Posted December 30, 2013 Just re-read my bad tired an didn't read what you was after Quote
