All you need is a ruler to set them up (roughly), measure the threads above the locking nuts and below them and keep a note. Then do the same on the other side. (do fronts and rear separate)
These are my measurements I got just now on my MiesterR's
Rear both sides: 87mm of thread above locking nuts, 33.5mm of thread below locking nuts
Front both sides:78mm of thread above the locking nuts, 24mm of thread below locking nuts
That's a bit too low at the back to and rubs without rolling the arches, so you'd want to heighten the back by 10mm to stop this.
If you want it to handle spot on with them all setup correctly you need to get it corner balanced :) cost about £100-£150 I would say (2-3hr labour).
I think you'd get it done at some Performance Tuning places with garage services, I looked at one near me and it's 50 mins away is the closest place :(
Edited by Jamie5414
