SevyjackSR Posted January 6, 2014 Share Posted January 6, 2014 So got some meister what's the best way to set these up or some garages that will do it any info will be useful thanks Quote Link to post Share on other sites
Jamie5414 Posted January 6, 2014 Share Posted January 6, 2014 All you need is a ruler to set them up (roughly), measure the threads above the locking nuts and below them and keep a note. Then do the same on the other side. (do fronts and rear separate) These are my measurements I got just now on my MiesterR's Rear both sides: 87mm of thread above locking nuts, 33.5mm of thread below locking nuts Front both sides:78mm of thread above the locking nuts, 24mm of thread below locking nuts That's a bit too low at the back to and rubs without rolling the arches, so you'd want to heighten the back by 10mm to stop this. If you want it to handle spot on with them all setup correctly you need to get it corner balanced cost about £100-£150 I would say (2-3hr labour). Quote Link to post Share on other sites
SevyjackSR Posted January 6, 2014 Author Share Posted January 6, 2014 Sounds good mate Where do you get corner balance done? Quote Link to post Share on other sites
Jamie5414 Posted January 6, 2014 Share Posted January 6, 2014 (edited) I think you'd get it done at some Performance Tuning places with garage services, I looked at one near me and it's 50 mins away is the closest place Edited January 6, 2014 by Jamie5414 Quote Link to post Share on other sites
SevyjackSR Posted January 6, 2014 Author Share Posted January 6, 2014 Aw fumming got a fair few around here ill do some research thanks for info tho Quote Link to post Share on other sites
Rob Scott Posted January 13, 2014 Share Posted January 13, 2014 you can do it youself with bathroom scales Quote Link to post Share on other sites
