Alright guys just wanted to know any opinions on the best spark plugs to buy heard copper tip ones are good but i don't really know much about them
It's standard inters with a td04 set up
Cheers lads!
X2, plus your be safe from the problem sometimes associated with Iridiums.
What problems can you get from iridiums?
Iridiums are not so forgiving if they get a good dose of black soot from over fueling, that any you generally wreck them if you try and clean them. But they should be fine as long as your fueling is spot on. Maybe more suited for stock or lightly modified setups. NGK standard plugs are all I ever use (although a different heat range) for the simple reason they're cheap, easily cleaned and commonly available so I don't mind changing them out if need be
