marble Posted January 18, 2014 Share Posted January 18, 2014 Alright guys just wanted to know any opinions on the best spark plugs to buy heard copper tip ones are good but i don't really know much about them It's standard inters with a td04 set up Quote Link to post Share on other sites
Idrees Posted January 18, 2014 Share Posted January 18, 2014 NGK Iridiums, as found here: http://www.id-workz.co.uk/index.php?main_page=product_info&cPath=3_1118_8_1185&products_id=404&zenid=00256d46f6658f31ed41b861e5ad1309 Quote Link to post Share on other sites
aidanep71 Posted January 18, 2014 Share Posted January 18, 2014 I'm using the copper core plugs at the moment and there spot on the brother also uses them in his 400hp drift car with no problems either Quote Link to post Share on other sites
maddox710 Posted January 18, 2014 Share Posted January 18, 2014 Ngk all day long although Denso do good plugs Quote Link to post Share on other sites
AdamB Posted January 18, 2014 Share Posted January 18, 2014 Coppers are fine, just need replacing more often Quote Link to post Share on other sites
DevonGT Posted January 18, 2014 Share Posted January 18, 2014 On 1/18/2014 at 9:40 AM, AdamB said: Coppers are fine, just need replacing more often X2, plus your be safe from the problem sometimes associated with Iridiums. Quote Link to post Share on other sites
marble Posted January 19, 2014 Author Share Posted January 19, 2014 Cheers lads! On 1/18/2014 at 12:54 PM, DevonGT said: X2, plus your be safe from the problem sometimes associated with Iridiums.What problems can you get from iridiums? Quote Link to post Share on other sites
aidanep71 Posted January 19, 2014 Share Posted January 19, 2014 The iridium tips have been known to come off wrecking the bores Quote Link to post Share on other sites
Idrees Posted January 19, 2014 Share Posted January 19, 2014 On 1/19/2014 at 11:30 AM, aidanep71 said: The iridium tips have been known to come off wrecking the bores I've never heard of this before, any links? Quote Link to post Share on other sites
aidanep71 Posted January 19, 2014 Share Posted January 19, 2014 No but but have been told by some well respected tuners both here and the uk Quote Link to post Share on other sites
DevonGT Posted January 19, 2014 Share Posted January 19, 2014 On 1/19/2014 at 12:18 PM, aidanep71 said: No but but have been told by some well respected tuners both here and the uk Same here, not common but as been known to happen. Quote Link to post Share on other sites
Chris_GlanzaV98 Posted January 19, 2014 Share Posted January 19, 2014 ngk heat range 7 should be fine Quote Link to post Share on other sites
hookie663 Posted January 19, 2014 Share Posted January 19, 2014 I used to use iridium ones but have changed to copper ones Quote Link to post Share on other sites
Stu Posted January 20, 2014 Share Posted January 20, 2014 Iridiums are not so forgiving if they get a good dose of black soot from over fueling, that any you generally wreck them if you try and clean them. But they should be fine as long as your fueling is spot on. Maybe more suited for stock or lightly modified setups. NGK standard plugs are all I ever use (although a different heat range) for the simple reason they're cheap, easily cleaned and commonly available so I don't mind changing them out if need be Quote Link to post Share on other sites
