Barnz74 Posted January 20, 2014 Share Posted January 20, 2014 HiDoes anyone know if hesitation and jerky throttle reponse is actually fuel cut? I'm getting an engine light and code 31 come up and I've been told it's most likely the wiring to the HKS FCD that could be dodgy, I can believe that with the history of the car...... but could the map sensor be fooked? Does anyone have a link to the FCD wiring diagram?Help appreciated. Quote Link to post Share on other sites
Barnz74 Posted January 22, 2014 Author Share Posted January 22, 2014 Hi - I've been told the FCD wiring is a bodge job by the last owner, so I'm ripping that out and making it all nice n neat, see if that fixes it thanks peeps Quote Link to post Share on other sites
Turk Posted January 23, 2014 Share Posted January 23, 2014 Can you let me know how it goes. I e got the same problem and a fucked up wiring job. Previous owner put the fcd in the engine bay and one of the wires was shorting out on my inlet manifold. Taped it up now but i still get flat spots when i give full throttle between 1-3k rpm Quote Link to post Share on other sites
Barnz74 Posted January 23, 2014 Author Share Posted January 23, 2014 Can you let me know how it goes. I e got the same problem and a fucked up wiring job. Previous owner put the fcd in the engine bay and one of the wires was shorting out on my inlet manifold. Taped it up now but i still get flat spots when i give full throttle between 1-3k rpm Sure I'll let you know Turk. That's what I get. Flat spots when I accelerate around 2-2.5k and it's jerky as hell. I've been told it's fuel cut. My FCD is behind the centre dash on the transmission tunnel so I probably kick it with my left foot sometimes........... I'm going to solder it all up when I get some space and take my MR2 out of the garage - or it's sunny! Quote Link to post Share on other sites
mikey4410 Posted January 23, 2014 Share Posted January 23, 2014 do ureself a favour and dont run a fcd.there awful and really screw up the signal speed to ecu giving time for an issue momentarily.and u have to turn up the fueling far higher than normal to compensate for the ecu not seeing things right.tryed one ages ago and witnessed first hand the effect on fueling via my a/f gauge Quote Link to post Share on other sites
Adam-Gt- Posted January 23, 2014 Share Posted January 23, 2014 I got a fcd on my car and I'm not having any issues at all But i haven't looked at my wiring might of been done properly but I doubt it as precious owner was a bodge job at fixing stuff Quote Link to post Share on other sites
Turk Posted January 23, 2014 Share Posted January 23, 2014 Im planning of removing it anyway Quote Link to post Share on other sites
Barnz74 Posted January 29, 2014 Author Share Posted January 29, 2014 Im planning of removing it anyway Me too now, I don't think it's raining tomorrow so I'm checking it over then Quote Link to post Share on other sites
