Gearbox, diff & transfer box recommendations HERE
Getting the right oil for gearboxes, diffs and transfer boxes can be tricky, so please ask here if there is any information that you need.
To help us to give the most accurate advice possible we do need some information about your car. e.g.
Make:
Model:
Year:
Manual/Auto:
Performance Modifications:
Driving style: (road / off-road / track etc.)
Any other information that may be relevant: e.g. approx BHP if modified, any transmission problems
What recommendation are you looking for? Gearbox, diffs, limited slip diffs, transfer boxes etc
Any oil we recommend is available to buy from us (if you would like to) for delivery throughout the UK and many destinations Worldwide. We offer a really extensive range of oils and lubricants from 11 major oil manufacturers at prices much lower than the high street and main dealers. We stock oils and fluids that meet pretty much all manufacturers and international specifications. Our brands include, Silkolene, Fuchs, Gulf, Castrol, Motul, Mobil, Millers Oils, Shell, Valvoline, Amsoil and Red Line.
Plus, as the Club is a member of our club discount scheme you can get discounts of at least 10% across our entire range.
To redeem your 10% club discount simply use the following club discount code at the checkout.
UKSO
Once the code is added at the checkout you will then receive your extra 10% club discount. However this discount code cannot be used in conjunction with other offer codes, BUT the code can be used in conjunction with any of our offers on this page HERE that do not require offer codes.
Any questions please ask here or contact us via email at sales@opiepoils.co.uk
Finally, if there are any products we don't stock and you have difficulty getting hold of elsewhere, let us know and we'll see if we can stock them.
We look forward to being of help!
Cheers
Tim, Opie Oils
You can also contact us by phone on +44 1209 215164
(All oils recommended are available to buy online at my web site)
What transmission fluids would you recommend for a 4wd starlet Tim ?
Gearbox, transfer box & rear diff ?
Make: Toyota
Model: Starlet EP85
Year: 1995
Manual/Auto: Manual
Performance Modifications: Bolt ons to run 220+ bhp
Driving style: Road, some track & drag
Make: Toyota
Model: Starlet EP91 na
Year: 1998
Manual/Auto: 3speed auto a132l
Performance Modifications: maybe almost 100bhp?
Driving style: Fast road, raped from cold, full throttle gearchanges and semi regular launches
Make: Toyota
Model: Starlet EP85
Year: 1995
Manual/Auto: Manual
Hi
You need a 75w-90 for the gearbox and diffs.
If you want to go for the best, the Millers CRX 75w-90 NT, Gulf Competition, Motul Gear 300, Redline MT90 and Millers TRX are ideal for the gearbox. The Castrol Universal, Motul Motylgear and Fuchs Gear Syn are all decent alternatives. The Fuchs Syn 5, Millers CRX, Redline 75w-90 GL5, Motul Gear 300 and Gulf Competition are ideal for the diff. The Fuchs Sintopoid, Castrol Syntrax Longlife, Millers TRX, Motul Motylgear, Mobil SHC and Amsoil FGR are also good choices.
I don't have a listing for the transfer box, but I would have thought that a 75w-90 would be ideal for that too.
Cheers
Tim
Make: Toyota
Year: 1998
Hi
Due to the gearbox specs I would go for either the Amsoil ATF, Motul Multi ATF, Fuchs ATF4400, Gulf Multi Vehicle ATF or Millers Millermatic ATF SPIII.
Cheers
Tim
