Glanza v sunroof model 040 white. Lovely condition. Good spec
Year:1996/7
Model: Toyota starlet glanza v 1.3 manual
Tax: none
MOT: 18.1.2015 ...next year
Mileage: around 95000 miles clocks are and always have been in km
Description: Here is my Toyota Starlet Glanza v 040 white sunroof model I spent a long while looking for the right one to own myself and I thought this was the one! Only problem I have had with the car was the paint was a bit poor and front bumper needed attention I have had her fully re-sprayed and she looks lovely and shines like a good un. Also had a little oil leak which was the sump it wasn't sealed well enough that got re-sealed and has not leaked since. Treated her to some new parts, crank shaft seal ( thought that was the oil leak problem but was just the sump so replaced anyway as had all the gearbox out to solve the problem fitted a spec 6 puk clutch too at the same time) hand brake cables both sides, yellow stuff pads, magnocore ht leads, t.d low temp thermo, t.d gaskets, yellow engine hoses full set, Bosch battery.
Engine
OEM LSD gearbox
Blitz nur spec full exhaust system
Blitz decat
Hks actuator
Magnacore ht leads (new)
Spec 6 paddle clutch (500 miles)
Triple core Alloy half rad
Yellow engine hoses ( new )
Tuning developments low temp thermostat ( new )
All new engine oil and clutch, brake fluid
New gaskets from tuning developments
Hid front mount with short route piping
Greddy dump valve
255 walbro fuel pump
Bosch Battery (new)
R.w developments air filter relocation kit
Cusco catch tank
Lowered on tein 40mm springs
Front strut brace
All brakes have been removed and cleaned up and serviced
New yellow stuff brake pads on front
Front grooved and dimpled discs
Hel braided brake lines
Hand brake cables both sides (new)
Gt front seats mk1
Depo Boost gauge
Cat 1 alarm autowatch with paper work
Momo millennium steering wheel
Indigo dials
Stripped rear I do have the rear seats and all plastics to go with the car
Spear wheel
Varis front bumper
Varis rear bumper
15" rota x alloys
Uniroyal tyres all new last year
Tegiwa wheel nuts
98 spec rear lights
Starlet door sills
Roof mounted air purifier
Front cup holders
Parking pole switch
Sunroof fully working
Price: £3800 ovno
Contact Details: pm or text me on 07947127274.
Cheers Matt
