djhasin Posted January 26, 2014 Posted January 26, 2014 My idle was ok before and used to go really low that it would stall so i adjusted the throttle screw to increase the idle.. anyways i took the intercooler pipe to clean the throttle body with carb cleaner and sprayed loads to clean out all the shit.. put everythinf back together and its idling very high now and i even turned down the screw on the tjrottle body to decrease idle but stil idles high on a warm engine at 1250 revvs.. any ideas anyone Quote
JayJ Posted January 27, 2014 Posted January 27, 2014 Check for vacuum leaks and clean your ICV, if the copper thing inside the valve is broken, replace the valve. Quote
Stu Posted January 27, 2014 Posted January 27, 2014 Or maybe the cleaning solvent may have got into the idle bypass diaphragm under the throttle body. Take the intercooler pipe off again and put your finger over the idle bypass intake hole before the butterfly and see if the idle drops. Quote
djhasin Posted January 27, 2014 Author Posted January 27, 2014 (edited) Well ive unplugged the icv and nothing happens and theres no change in revvs or engine sound.. but ill get that pipe of and have a look but doesnt that intake hole have a nozzle on the body which a hose goes into it? If yes ive removed it and the idle goes higher Edited January 27, 2014 by djhasin Quote
Stu Posted January 27, 2014 Posted January 27, 2014 Nah meaning the larger hole in the bottom that runs down into the idle up diaphragm under the throttle body Quote
djhasin Posted January 27, 2014 Author Posted January 27, 2014 Ook ill check it out tomoz n hopefully it wont be raining.. what if it does/ doesnt slow down? Quote
