liss Posted January 29, 2014 Posted January 29, 2014 Hello guys, I've bought some Accord type r recaro's and after a little bit of reading it seems that everyone is modifying the standard rails as opposed to buying recaro or bride ones. Today I have stripped down my passenger seat and have drawn a blank as to what needs to be done next? I was under the belief that the seat would just be bolted to the rail and it would just come away ready for a couple of plates to be welded on but it appears that this is not the case? Are the seats in my EP91 just different from everyone else's? Do I have to butcher and cut these rails up to make them flat ready for plates to be welded in? What are my options? Any help would be great! pics below. Quote
Zeldoz Posted January 29, 2014 Posted January 29, 2014 Waiting for answers here, as i plan on doing the exact thing. Quote
liss Posted January 29, 2014 Author Posted January 29, 2014 Waiting for answers here, as i plan on doing the exact thing.Yep I'm hoping someone has come across this before as I'm desperately trying to do this on a budget! Recaro/Bride rails are too expensive Quote
karl. Posted January 29, 2014 Posted January 29, 2014 What was done to my type R seats is the feet were cut off the glanza rails and welded onto the honda seats. Maybe no good to you but? Quote
TrisK Posted January 29, 2014 Posted January 29, 2014 They way i did it was: Buy one of these from demon tweekshttp://www.demon-tweeks.co.uk/performance/seat-mounting-frames-universal/recaro-double-locking-runners-left-right-hand-bow-inside Drill off the spot welds that hold the feet on the standard rails, bolt them onto those universal rails Job done Quote
Zeldoz Posted January 29, 2014 Posted January 29, 2014 They way i did it was: Buy one of these from demon tweeks http://www.demon-tweeks.co.uk/performance/seat-mounting-frames-universal/recaro-double-locking-runners-left-right-hand-bow-inside Drill off the spot welds that hold the feet on the standard rails, bolt them onto those universal rails Job done If there a hole to chuck a bolt through on the feed of OEM rails then? Or, do you need to make one? Also, same goes for the rails you linked, is there a bolt hole or do you need to drill? Quote
TrisK Posted January 29, 2014 Posted January 29, 2014 If there a hole to chuck a bolt through on the feed of OEM rails then? Or, do you need to make one? Also, same goes for the rails you linked, is there a bolt hole or do you need to drill? THeres a hole on the rail i linked and on the seats you drill where the spot weld was, which you had to do to get the feet off the rail anyway Quote
Greenmachine81 Posted January 29, 2014 Posted January 29, 2014 They way i did it was: Buy one of these from demon tweekshttp://www.demon-tweeks.co.uk/performance/seat-mounting-frames-universal/recaro-double-locking-runners-left-right-hand-bow-inside Drill off the spot welds that hold the feet on the standard rails, bolt them onto those universal rails Job doneis that price for a pair or single rail?? Quote
TrisK Posted January 29, 2014 Posted January 29, 2014 is that price for a pair or single rail?? Single rail i think lad Quote
liss Posted January 29, 2014 Author Posted January 29, 2014 Are there companies that will fabricate rails for you? Quote
lee0100 Posted January 30, 2014 Posted January 30, 2014 I done this with impreza seats, took the standard rails off my gt seats and lined them up with the impreza seats marked where I needed to drill holes then nut and bolted the rails on.Took awhile to line them up and getting them to sit level but seem fine Quote
Dmoss468-jdm Posted July 25, 2014 Posted July 25, 2014 Has this been done yet as I still want to know Quote
