Stripping standard seats to use rails for recaro's - help needed (including pics)
Hello guys, I've bought some Accord type r recaro's and after a little bit of reading it seems that everyone is modifying the standard rails as opposed to buying recaro or bride ones.
Today I have stripped down my passenger seat and have drawn a blank as to what needs to be done next? I was under the belief that the seat would just be bolted to the rail and it would just come away ready for a couple of plates to be welded on but it appears that this is not the case?
Are the seats in my EP91 just different from everyone else's? Do I have to butcher and cut these rails up to make them flat ready for plates to be welded in? What are my options?
Any help would be great! :) pics below.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Waiting for answers here, as i plan on doing the exact thing.
Yep I'm hoping someone has come across this before as I'm desperately trying to do this on a budget! Recaro/Bride rails are too expensive :(
They way i did it was:
Buy one of these from demon tweeks
http://www.demon-tweeks.co.uk/performance/seat-mounting-frames-universal/recaro-double-locking-runners-left-right-hand-bow-inside
Drill off the spot welds that hold the feet on the standard rails, bolt them onto those universal rails
Job done
If there a hole to chuck a bolt through on the feed of OEM rails then?
Or, do you need to make one?
Also, same goes for the rails you linked, is there a bolt hole or do you need to drill?
THeres a hole on the rail i linked
and on the seats you drill where the spot weld was, which you had to do to get the feet off the rail anyway
Job done
is that price for a pair or single rail??
I done this with impreza seats, took the standard rails off my gt seats and lined them up with the impreza seats marked where I needed to drill holes then nut and bolted the rails on.
Took awhile to line them up and getting them to sit level but seem fine
  • 5 months later...
